Re: 97 Evinrude 175hp Thermostat vs. Overheating
Wide open throttle, the timing refers to when the throttle hits the full spark advance stop screw.<br /><br />To verify this you'll need to have your mechanic hook it up to a dyno, or you could get a test wheel a timing light and a BIG test tank. Or you could go with out the tank & test wheel and hang your 6 out on the back of your boat with the timing light and have someone you trust run the boat to its stops
