Purchased boat and motor 1996, low hours, motor failed within 2 weeks, burnt hole in #2 piston. Repaired however failed again (hole in top of #2 piston) within 40hrs, general running around 4000rpm. Fitted evinrude supplied motor top end with old running gear, tuned to run rich and prop was resized. Has run well for around 60hrs and then started to cut out, would restart immediately but then cut out 5 mins. later. Have done another compression check #1 110psi, #2 95psi, #3 105psi. All repairs have been done by the Evinrude dealer who now says it looks like #2 has failed again - enough is enough. <br />Has anyone had similar problems (what is cause) and why should motor cutout due to a piston problem?
