Re: 1973 50hp Evinrude electric shift won't start...Help!
Well guys, I replaced the battery cables, spark plugs (gapped @ .030"), the ignition coils and replaced the old gas/oil mixture. I put the motor flusher on it and cranked it after a few times of trying to crank it. Let it idle for a about a minute. About an hour later I took it to the river (about 6-7 min from my house) boat launch. It cranked right up the first time let it idle for a couple of minutes, then it died. I then realized the fuel line had fell off the tank. Reconnected it and it cranked back up. reved it about half-way a few times and disconnected it from the trailer. When I got out in the river, I ran it at half-throttle about a minute and wanted to see if it would go full-throttle. It used to bog down big time after about 3/4 throttle. Today, it went all the way full throttle, ran perfect. I played on the river for about 5-6 minutes and put it back on the trailer and shut it off. Well, I forgot to disconnect the fuel line and run the excess fuel out. I went to go crank it and it wouldn't crank the rest of the time I was out there. It ticks me off because it ran super smooth, when it was running, even at idle. Any ideas on what it could be?
