i just bought this boat knowing the motor needed some work.it had been sitting for 2 years it ran very poor.so i checked the compression and all the cylinders were on 140psi,the ignition was puting out a strong blue spark on all the coils so i went straight to work on the carbs which were gumed up pretty bad.i soaked em and rebuilt them making sure floats levels were set right,new fuel line all through and of course new plugs gaped at 0.35 ,drained all old gas and fresh 50:1 fuel mixture.runs alot better now but is hard to get warmed up and soaks all three plugs and is hard to start after running awhile and shut off also smokes a little.any suggestions?also could the thermostat be causing this problem?i havent check it.not sure how to get to it.iv got a manual on the way.
