prop question
tefsearch
I have a sunbird barletta 208 with an OMC 3.0L H.O. engine and a cobra stern drive. The prop on the boat is a michigan wheel aluminum 15 x 17. The top speed at wot (4,600 rpm) is 34 mph according to the gps. The boat gets on plane with two people on board at about 3,000 rpm. Is this the correct prop or is there a better one to use.
scubatrooper
Re: prop question
Tfox:<br /><br />I just installed a new 14 x 23 on my boat tonight. It was an exact replacement for the one I tore up.<br /><br />Mercury has a nice prop selector on this web page:<br /> http://www.mercurymarine.com/prop_selector <br /><br />Iboats.com (this web site) also has a nice prop selector at this web page:<br /> http://www.iboats.com/mall/propeller/ <br /><br />As far as what's the best size, I'd check the owner's manual and with a local boat dealer for advice so you can keep the engine running within its RPM range. Good luck.<br /><br />Steve
jlinder
Re: prop question
i would think that if you are getting WOT that is within specs you are loading the engine correctly.<br /><br />Do you know the reccomended WOT for your boat?
QC
Re: prop question
There are no "right" props, just good compromises. ;) I am guessing that particular OMC has a 4200 - 4600 range for WOT. Sounds like you are right there with a light load, which means you should still be there (towards the bottom) if heavily loaded. Seems like a good compromise to me. If you don't have a spare you need to buy something anyway. Learn as much as you can from all of the posts on propellers. There are lots. Also, review in the Engine FAQ section.<br /> <br />BTW, welcome.
Boatist
Re: prop question
TFox<br />I think the prop you have is a good match for your boat. You are getting the right RPMs at WOT.<br />I do not know your boat size and weight but the only thing I see is the 15 inch size is usually better for big heavy boats. I think with a 13 by 19 Stainless you would gain about 3 MPH and turn about 4300 rpms if your boat is under 3000 pounds. If it heaver then then I think you have the right prop.<br /><br />My boat a 1980 Crestliner is 21 feet and a beam of 7 foot 8 inches or 92 inches. It is an aluminum boat and weighs 2800 pounds dry. Motor is a 3.0 1980 OMC stringer 400 rated then at 140HP. I have two props that I use to adjusted for difference conditions.<br /><br />Prop 1 is 13 and 3/8 by 17 3 blade stainless OMC number 389948. I use this prop in lakes and rivers where we tend to start and stop more and not travel long distances. WOT RPMs is 4600 at 35 MPH.<br /><br />Prop 2 is 13 by 19 3 blade stainless OMC number 389510. I use this prop in Ocean and San Francisco bay where we do not start and stop alot and tend to cruse as far as 30 miles one way. WOT RPMs is 4200 at 38 MPH. This prop a little slower out of the hole and gets better fuel mileage. When fishing the ocean water my boat will weigh more as we always go with full tank and lots of big weights, 10 poles or more and lots of extra gear, cameras, change of clothes more jackets, water ect. <br /><br />A trip we make over and over to a fishing grounds 26 miles offshore we will travel right around 70 miles for the day. We will only go that far out when we can run at a natural planing speed of 20 MPH. When we get back we always fill the tank.<br /><br />With the 13 by 19 prop it will take 18 Gallons to refill so get about 3.88 miles per gallon.<br /><br />With the 13 3/8 by 17 prop it will take 21 gallons to refill so get about 3.33 miles per gallon.<br /><br />I do not know if this will help you or not but at least should give you an idea of what you could expect with a smaller higher pitch prop.
tefsearch
Re: prop question
Thanks for all the information. My boat is 20 ft. cuddy cab with a 7'9" beam. WOT is from 4,200 - 4,600 rpm. The boat was loaded with to 2 adults and dive gear. When I looked up a prop for my boat the one I have is listed as for a V6 or V8 engine.
