My 1989 90hp V-4 vro will run fine for about five min at 5000rpm then it starts running rough and slows to about 3000rpm. If I stop for about 30 minutes it will run at 5000rpm for about five miutes and then it starts acting up again. I have squeezed the primer bulb when the problem occurs and swapped fuel tanks and fuel lines. The motor is not over heating. The vro and warning horn have been disconnected. Could it be going into slow mode?
