Couple of things I have noticed. <br />Plugs are dark and wet after the motor runs.<br />Primer bulb on fule line never gets tight.<br />Fuel econ is really bad. <br /><br />Motor does not have the vro pump on it, have the bypass pump.<br />New coil<br />New plugs<br />Carbs were taken apart and no trash was found<br /><br />Is there an adjustmet to run the carb lean or rich and where is it?<br /><br />This is the picture of my choke, I'm almost 100% that its set correctly.<br />
