shocking prob
fireman57
Re: shocking prob
Check and clean all your grounds then run the engine if you can in the dark and see if you can see a wire arcing to the block or other surface. If it won't turn off I'd suspect your ignition key switch. You might also check the kill wire from the switch to the engine.
hendrixgod
Re: shocking prob
which wire is the kill. looked at book but couldn't really tell...<br />thanks
ezeke
Re: shocking prob
Black and yellow is the kill wire. It grounds the power pack when you turn the key to off.
Walker
Re: shocking prob
Pull the cowling off and fire her up and see if it still shocks.
hendrixgod
Re: shocking prob
my boat is still in the shop. i don't know what they are testing. i will let you all now when i get it back and what they found....<br />thanks
