1973 evinrude 115 water pump problems
Austinm
When starting the motor both in a bucket and with muffs, the water does not discharge from the two holes at the top of the midsection. Only a lot of air blowing out and a few drops spitting out. Using the seloc book i unbolted the lower unit and it dropped only about 2in. What am i missing?<br />also when running in a tub of water, the motor seems to be cool, the lower unit is as cool as the water but the midsection gets hot how hot should it be?
baxter66
Re: 1973 evinrude 115 water pump problems
Your not going to get a steady stream from the two holes it is just going to spit out of them. Water is also going to come out of the prop with the exhaust.You will not get a stream like the newer motors.
Austinm
any idea why the lower unit would not come off? did i not disconnect something?
alden135
Did you disconnect the shift rod?
baxter66
There is a bolt under torque tab above the prop and you have to remove shift rod linkage under carbs.
Austinm
are there repair manuals for this specific motor other than the seloc?
Austinm
is there an easy way to disconnect the shift rod? looking at it is looks like a the carbs have to come off
baxter66
I have an orignal service manual i got of ebay for 74 115.I removed the shift cable and the throttle cable.Then I was able to get to the bell crank bolt with a wrench.You will also need to loosen the ball joint on the outside closest to you so that the two flat pieces on each side of the shift rod can spread apart.I can send you a pic of that page in my manual.
baxter66
No problem I did alittle head scratching the first time I replaced mine.
