I have a 73 Johnson 65hp with a couple problems. 1). When you put in gear the motor seams to die out and you have to mannually pull and push the choke in and out. Then all seams to run fine. This happens almost every time I start out from idle. <br />2) when in full speed for a while the motor seams to loose gas and it will sputter for a sec and then run okay. One time the gas bulb went flat but the vent on the tank is fine. <br />Please helpppppppp if you can. <br />Thank You.....
