Re: "Hardspot" when turning crankshaft on 62 johnson seahorse 40 hp
I certainly do. Tell me what exactly you're after and I'll give you some pointers. Some of the bearings are available from bearing houses for substantially less money than Bombardier. On others the Bombardier part is often less than what you'll find at a bearing house.<br />The clutch dog is a fairly common service item (they wear out if people ease the engine into gear). Cost is about $80, and it's available from any dealer.<br />If you're needing new bearings and new gears, you might be better off picking up a used gearcase. They were common to many years and models so they sometimes go on ebay really cheap.<br />All Iboats carries for that l/u is a nice little aftermarket seal kit and water pump parts. The dealer can sell you the same stuff, but seperate. The spagetti is the rubber o-ring type cord that seals the cap. Actually the sealant really seals the cap since all the screw holes run inboard of it.<br /><br />But this is all future work. What you'll want to do right now is determine if it's worth doing. Slap that lower unit back together. Flip the clutch dog so it's good side engages the forward, forwardmost gear, slather the cap with sealant and fire it on. Fill 'er up with outboard gearcase lube (which will lubricate even if water leaks in). Then get the engine running and determine if there's anything else that needs to be done with it. Start with a compression check. There's no sense beating a dead horse.
