1971 100 hp outboard stalls at low idle wont restart...
raysold boat
my 1971 johnson outboard 100hp 4 cyl. starts and runs fine. until it I try to dock it it stalls at low idle and wont restart.. what should I check thanks Ray
OBJ
Re: 1971 100 hp outboard stalls at low idle wont restart...
Welcome Ray!<br /><br />Does it idle fine cold Ray? How long are you out running before this occurs? Does the engine stall all the time at low end and how do you get it to restart? Are you sure it isn't overheating?<br /><br />Sorry for all the questions but the answers or any history you can give will help. <br /><br />Have you checked for spark when the stall happens and is the compression good?
raysold boat
I dont know what the compression is (yet) motor runs and starts good when its cold or cool.. after 15 minutes of running when I let engine idle to coast into dock it stalled and would'nt start. I pulled two plugs they looked great and both had spark. after the motor cooled down it would restart no problem... what can I check about over heating, or could the coil be a problem when hot? thanks for any info you can give me. Ray
OBJ
You can check for over heat with the "touch" test Ray. Look for the flat areas on top of the block just forward of the heads. If you can get the engine started, let it idle for a while if it will. Then touch these flat areas with your fingers. At idle, you should be able to keep your fingers there for several seconds. If the block is hot, you will know.<br /><br />Check the spark. Each spark to each cylinder should jump at least a 7/16" gap with a strong thick lighting like spark.<br /><br />When was the last time the carbs were overhauled? Any maint history you can share would help. Pump been changed out or t-stats?
raysold boat
thanks I will check for hot spots. I just bought the boat this week and I dont know about the carbs last overhaul. or the t-stats. my friend owned the boat for the last 2 years and he only had one problem with it. last year he had a fuel cap vapor lock. sorry I dont know more. other than to say will get more information and post it asap thanks again. Ray
