Re: HELP NEEDED to ID a motor
For 5-bucks you got a heck of a deal! If the motor is basically sound (nothing broken or missing, decent compression and even between the cylinders) then it's fairly easy to rejuvenate that little 5.5. Pretty much all of the consumable parts are readily and cheaply available - coils, points, condensers, waterpump impellers, lower unit seals, carb kits, etc., and most are even available right here through i-boats! For about $100 you can replace all those parts, give the motor a good decarboning and it should last another 50 years!<br />- Scott
