too much oil
rogerbowtorc
I have a 2000 70 hp johnson ob and the carbs are filling with oil when the engine is not running. can anyone suggest a fix?<br /><br />Thanks<br />Roger
ob
Re: too much oil
Insure the oil reservoir is venting while out of use and not building pressure and forcing oil thru the OMS pump.Also could be a leak thru seal issue from the oil portion of the pump itself.How long does it set out of use before the carbs are flooded with oil?
rogerbowtorc
Re: too much oil
I'll check for venting. A couple of days seem to be enough to keep it from starting.<br /><br />Thanks<br />Roger
