Hi guys,,<br /><br />reading old posts, I saw a schematic post that a potentiometer can be used to simulate a fuel sender unit...<br /><br />I have caps like this in my tanks,,<br /><br />
<br /><br />and I'd like to convert them to electric sender units..<br /><br />could the top plastic screen be taken out and a potentiometer/variable resistor be attached to the needle pinion????, (which is a rotary style, see pic above)<br /><br />I just found a kit on westmarine that seems to do this,, but its 43USD, which is rather expensive for what is essentially a small coil.<br /> electric conversion sender unit <br /><br />Also, what resistance range potentiometer should I get for a fuel sender,, its for a teleflex guage...<br /><br />also should I be worried about current/fire danger here how much current does a fuel sender use?? <br /><br />any tips would be fantastic..<br /><br />regards<br /><br />Frank
