1988 Mercury v-6 135hp outboard on a SeaRay Seville. I had the boat in the shop last year for fuel pump problems, and I was told that the Spark Advance had been set ahead, so the shop set it back to factory spec. When i got the boat home, it ran ok, but had no power when compared to before. It would hardly pull a skiier, and top speed had dropped from the high 40's,, to barely cresting 40 mph. I reset that back to where it was, and got my performance back, but I am still curious if this is an indication of another problem. They had done a compression test, which was very good. I have had ignition work done in the past, and feel that with the fuel problem fixed it is running as good as it should. Any thoughts would be appreciated!
