joechristo
- Jul 1, 2002
- 7
I have had an ongoing problem with my outboard. It is starting and running, but the engine does not sound like all the cylinders are firing. It sounds like it tops at 4000 rpm instead of 5500 rpm.<br /><br />Only going 30, the cooling system is working ok, and it idles fine, just when trying to cruise it is not getting the speed it should. It is also slow off the line. Last year it was stalling off the line, but I think that is resolved with new fuel lines.<br /><br />What would be my first step, how would I check for spark on an outboard, a guy I work with said to just take the boot off the plug, crank it, and see if there is a spark while holding the boot near the engine block.<br /><br />Also, I know I am supposed to check for compression, but I see all these instructions to put the engine in forward, the crank it. How is this possible? My throttle locks out the starter when you put it in gear. Am I just supposed to use the idle lever?<br /><br />Thanks in advance for any replys, good forum, other forums like this have been disappearing.<br /><br />Thanks,<br /><br />Joe
