I just got my boat in the water after 10 months,due to an illness. It is a 2 stroke 140 Suzuki, It started fine but as I increased the throttle, it was a little rough. I had put stabilizer in last fall. Does gas go bad after a period of time?
I keep a one gallon can in the garage for mowing the lawn. It lasts me from April to October and I have never had it go bad or cause a problem. Not saying a lawnmower is an outboard, but I am questioning that gas goes bad in 30 days. <br /><br />This is one of those cases of how safe do you play it. Most here take the cautious approach, and this is hard to argue. 10 months is not that long considering he did add stablizer. I would say the chances are pretty low that piston dammage would occur. Why risk it? -- fair question and so is how much risk are you looking at?<br /><br />I agree that if you are going to leave it sit a long time, you are better with a full tank. I only run a 6 gallon tank, and typically burn about 4 gallons on a long day. I fill it before I go home, and I run my boat almost every week. When I had a 17 gallon tank, I never filled it full because the most I used in a day was 8 gallons. I tried to keep it around 1/2 full when it was on the trailer. I filled it full at the end of the year and stablized it. It sat a solid 6 months like that and never went bad. My thinking is fill the tank to prevent corrosion due to condensation. I worry more about crap in the tank than bad gas.<br /><br />Is it fair to say that today's 87 octane fuel is more stable the the old regular leaded fuels of years past? I think it is.Originally posted by walleyehed:<br /> Burning that tank out "may" (and I have seen this)be enough to cause sufficient detonation to cause piston damage. Can, does, and will happen.<br />You also would be advised to fill the tank to the top...small amounts sour much quicker.
Originally posted by Paul Wiseman:<br />I keep a one gallon can in the garage for mowing the lawn. It lasts me from April to October and I have never had it go bad or cause a problem. Not saying a lawnmower is an outboard, but I am questioning that gas goes bad in 30 days. <br /><br />This is one of those cases of how safe do you play it. Most here take the cautious approach, and this is hard to argue. 10 months is not that long considering he did add stablizer. I would say the chances are pretty low that piston dammage would occur. Why risk it? -- fair question and so is how much risk are you looking at?<br /><br />I agree that if you are going to leave it sit a long time, you are better with a full tank. That is why I said if it was a full tank, I would not worry much. I only run a 6 gallon tank, and typically burn about 4 gallons on a long day. I fill it before I go home, and I run my boat almost every week. When I had a 17 gallon tank, I never filled it full in the summer because the most I used in a day was 8 gallons. I tried to keep it around 1/2 full when it was on the trailer. I filled it full at the end of the year and stablized it. It sat a solid 6 months like that and never went bad. My thinking is fill the tank to prevent corrosion due to condensation. I worry more about crap in the tank than bad gas.<br /><br />Is it fair to say that today's 87 octane fuel is more stable the the old regular leaded fuels of years past? I think it is.Originally posted by walleyehed:<br /> Burning that tank out "may" (and I have seen this)be enough to cause sufficient detonation to cause piston damage. Can, does, and will happen.<br />You also would be advised to fill the tank to the top...small amounts sour much quicker.
