Re: Using water to decarbonize???
Squeakit,while atomizing water through cylinders may have some effects on decarbonizing,I still would not recommend it as an option when products for this have been formulated .None of which are water.Some of the large stationary diesels I have maitained over the years had fixed atomizers on cylinders used for this purpose on occasion,however these engines also had pressurized oil circuits and vented crankcases which accomodated escape of residual moisture reaching con bearings and mains through blowby.Atomized water through intake on two stroke outboard while it may dynamically remove or cause release of some carbon on piston head ,I would consider to be crude intervention.I personally would stick with products recommended for this purpose as opposed to risking the possibility of deleterious effects to rotating components by using water.No disrespect,intended for previous posters.Just my opinion.
