Re: Mercruiser 3.0 Running Problem
Conor<br />Need many more details to be of any help. Is the engine missing on one cylinder?? Tell us what you mean by running poorly. Low speed miss can be bad Valve, blown head gasket, low speed carb adjustment, timing off. Is it missing, coughing, surging. What year is it and how old is Exhaust manifold and do you run in salt water. If it is missing I would start with a compression check. Also you can pull one spark plug wire at a time and find out which cylinder it is. If number four has low compression and it is missing I have a idea what it could be. Let us know what you find and will see if can help.
