forward gear is out on old mercury
jlc
Ihave a mercury outboard sn#958803 it is green not black. The forward gear is not working. I've got the foot off of it but I can't get the shaft and gear apart.How can I do this and can I get parts for it? Thanks for your help. J.L.Crouch
Trevor
Re: forward gear is out on old mercury
suggest reding a manual this a challenge that requires some knowlege and some special tools chilton or seloc have good manuals out. when you put it back to gether your shimming is vital !!!!
Chinewalker
Hi J.L.<br /> Also, your model number would help a great deal. The serial puts you in about 1955. Depending on model, could be any number of things holding you up...<br />- Scott
rickdb1boat
jlc, <br />The HP would be helpful, also. Many numbers match up to different HP motors.
jlc
the model # is 25 Thankyou J.L.Crouch
Chinewalker
I'm guessing you mean a Mark 25. I would suggest getting the 1965 and prior Mercury service manual, available from Grubb's Marine at www.oldmercs.com . You'll need to make a tool or two out of some pipe stock to get it apart. The gears themselves are not actually attached to the propshaft. The pinion gear is bolted to the driveshaft...<br />- Scott
