In my service manual the idle screw is used to set up low speed timing! If I want to lower or raise my idle will it effect my timing if I turn this screw? My problem is after a high speed run,when I return the throttle handle to neutral the RPMs race up to about 1300RPM. If I sit for a couple of minutes it eventually idles back to about 750 RPM. If I shift at the higher RPM the engine really clunks into gear.(Not good).I took my engine to dealer to have timing checked and this is when problem started. I noticed that the throttle cam and roller adjustment mark was changed from the original factory setting. I'd like to re-adjust according to my manual but the timing is the thing that I'm afraid of. I don't know how to do it, and I don't have the equipment.I don't want to go back to dealer. Lots of problems there. So if I make any idle speed or linkage adjustments will i screw up timing ?Thankyou for your time!
