I have a 60 hp mariner outboard that runs great and when engaged prop turns at idle speed, but give it throttle the prop does not respond along with motor speed, is there a shear pin, or some kind of clutch on the output shaft? I need an exploded diagram of the lower unit, or info on this problem. I know it's had to happen to someone out there! Thanks
