Re: Advantages of 3 cylinder over 2 cylinder??
I agree with JB, while there are differences between engines with different number of cylinders, displacement (the sum total of cylinder displacement) has the largest impact on power output. A really well designed and built single cylinder engine (up to a certain size)could put out as much hp as an average designed multicylinder of the same displacement. One reason manufacturers go to more cylinders is smoothness, there are certain numbers of cylinders and layouts (V angles) that provide smoother firing orders. Another reason is flow problems with really large piston bores. I suspect that in some cases it would be economical to offer a detuned version of a larger horsepower model as a lower hp version.
