How to replace impeller in 78 mercury?
jsp123
Hello got a replacement impeller in today, but dont know exactly where it is located? It is a 50 hp, 78 mercury outboard. Please help me replace her.<br /><br />Thanks!<br /><br />Justin
wallydiver1
Re: How to replace impeller in 78 mercury?
ya ur impeller is located in the lower unit.. its not too hard to take off either.. should be 4 or 5 bolts.. the impeller housing is located right on the main drive ull just have to take the top off and the gaskets pull the old one out and put new in.. make sure not to fiddle around with gears when lower unit is dropped, it could be trouble.. just make sure u leave it in the same gear as when u took it out.. hope that helps..
bhold
great link andrew, thanks...
