My 150XR2 is will run at wot for about 3 minutes and then will lose power. I can back off a hair and leave my hand off the throttle and engine will pick up power by itself and start to rev up again and then will fall back. I ran the boat for 50 miles on Sunday and had no problems at all. If I squeeze the bulb while its running the bulb flattens out and will not expand again (this sounds like it might be normal lf no leaks in hose). I changed the fuel filter on the port side of engine. Any ideas on this problem?
