Engines(twins)both show temp normal at idle to 3000 rpm. Engines overheat at rpm 3000 and over. Port worse than starbd. Usually takes 5-10 min. Changed impellers, thermostats, waterpump. Considering replacing water deflectors in cylinder head or removing powerhead entirely to check for carbon debris or other clogs. Engine carefully maintained and has less than 350 hrs. Both procedures costly. Which is more likely cause? Any other suggestions? <br /><br />Any service bulletins on this outboard overheating?
