'74 Merc 150hp flooding carbs and leaking fuel through exhaust...
Oblivious
When primed, fuel leaks through the exhaust like Niagra Falls. Its a 1974 Mercury outboard 150hp.<br /><br />I checked needle valves (when kept closed manually they do not allow fuel to drip), I adjusted valve levers to the specs in book, floats don't get stuck when pressed into bowl using a screwdriver, etc, float springs are within spec. <br /><br />Can floats themselves go bad (they look to be the originals)? They are still bouyant though perhaps they are saturated a little too much? Or could it be the float springs? I really don't know where to look next! What else can it be? The engine would otherwise run very well fuel is just gushing out the exhaust. :mad: <br /><br />Thank you!
mellowyellow
Re: '74 Merc 150hp flooding carbs and leaking fuel through exhaust...
perhaps the check valves in the pump are allowing<br />fuel to run back into carb? get a manual at bottom<br />of this page or local library. get new carb kits<br />and new pump kits, follow the manual and you should<br />be all set.<br />good luck,<br />M.Y.
