I'm troubleshooting a constant temp alarm on my port-side '95 150HP Merc. Engine is squirting and running smoothly through all throttle ranges and loads. There is no temp gage installed. Boat is marina-kept on a rack and I don't get down to it enuf be able to get very familiar with the powerhead(s). <br /><br />I suspect a faulty sending unit and would like to know a little in advance where to spot the sender on the powerhead so I can either swap it with the starboard engine's unit or simply pull it to run a bench test. Also, any idea what the little sender may cost? <br /><br /> Thanx,<br /><br /> Ed
