Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
You would be safe to run the engine around the 5250 RPM range..it might be alittle higher than that but I do not have the spec's in front of me.<br /><br />If I recall correctly the gear ratio is 2:1.<br /><br />Its been a while since I have had to answer that ?<br /><br />TMD
Hello:<br /><br />I believe that the recomended RPM range is 5000 - 5500. But these motors will go to 6000 without any damage. I have a mechanic that told me to get as close to 6000 as I can without going over. I hope this helps.<br /><br />Craig
That's correct, 5000-5500 rpm and 2:1<br /><br />None of the motors in this series are specified higher rpm range (150 hp is the same, 90 hp is lower).
