Re: 1970 Larson Tri hull rotten floor
Just fixed similar issue...for a hole potentially 5" in diameter cut the carpet 12 to 15" around the soft spot. Cut three sides of a square and pull back, then carefully cut the floor to get a look inside. If it's only that spot or a little larger cut out to solid wood. Chances are that some thing under is also a problem. You may be able to make a repair by cutting some more flooring to sister a stringer or something like that. I had a 8" floor hole to repair. Cut a piece to fit through the hole and pull it up against the underside of the floor. Use water-proof glue on it and don't forget to put something on it to hold on to, like a screw, etc.<br />Drill pilot holes and screw through the floor to attach the piece from the underside. Then cut a piece of ply the same thickness, size and shape as the hole. Glue and screw that down, then glue down the carpet.<br /><br />If you luck out and don't have alot of rot, you'll be ok. The key is to work neatly and pattern the cuts, then carefully glue down the carpet.<br /><br />I would not go over the entire floor unless the stringers are sound, otherwise you'll have sagging floor very soon and a lot more to pull up later.
