I have a 16ft 1983 Invader runabout I/O that I will probably be going out on by myself. Putting it in the water by myself as long as there is a dock isn't a problem. Back into the water, tie the front line to a dock cleat, back down a little more and hit the brake. It will float right off.<br /><br />However, because of my size (265 lbs), age and back and knee problems, I can't run the boat up on the trailer and then climb off the boat onto the tongue of the trailer as I've seen others do.<br /><br />If there are others who have the same problem, what do you do that allows you to put your boat on the trailer by yourself? All suggestions (except lose weight) will be appreciated.
