I have a 200hp merc 1986 model, it has a small plate on the lower right side of the engine (looking toward prop) it has a small hole in the lower part of this plate which has two small bolts holding it in place. I assume this to be some sort of weep hole since it it leaking water. This engine has been modified and has no restrictive covers over the carbs, this causes my engine to pick up water that is inside the cowling. Could someone please explain what this may be and what is needed to repair it. Thanks,<br /><br />buddy8097
