Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Where exactly is this water spraying out? Mid leg? If so this is normal..the water flow should increase as the engine heats up.<br /><br />The majority of the water is released out thru the prop.<br /><br />TMD
yea it comes out of the port hole on the back of the engine,not the hub.The reason i was concerned is because there is a slight leak "a drop now an then"at the bottom of the exhaust cover on the block.
Is the "pee hole" hose, the small telltale hose that hangs on the starboard side properly attached, or, better still, is it clear of debris? It sounds like one of these could be what explains the irregular drops you mentioned. Just a suggestion!<br /><br />Gil
