DadaRabbit
- Jan 11, 2004
- 14
2001, 150 merc, carb.<br />Replaced impeller following the repair manual. Went to test it using a hose and ears while running motor. No water coming from the upper water discharge hole. I connected the hose to the upper flush connection (no motor running)and water did come from the discharge hole. Is it possible that the plastic sleeve became dislodged from the top of the plastic pump housing? Manual didn't say to seal the sleeve to the pump housing. Should this be done? Or could there be another problem?
