Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
my trim motor on my '86 90hp merc is only working going down, nothing when switch up. The motor is now down and when I turned the override screw to override the hydraulic, the screw sheered off. what the heck can i do now to get it up ??
Jim,my guess is a bad trim solenoid.Your motor has three of them.All have red and black wires .Two also have the trim wires you need to jump.One has a green wire for down,the other has a blue wire for up.The solenoid with the blue wire...use a jumper wire and touch the heavy red wire to the small blue wire.If it goes up okay... replace that solenoid.<br />DHP
