Re: I need some help. Overheat alarm only @ WOT.
mc, that's a good test, as it tells you what the water temp is at the time (or shortly after) the alarm goes off....<br /><br />However, your overheat sensor is measuring metal not water... So, either the metal is getting up to 260F and the water isn't getting anywhere near that (unlikely), or you're sensor is installed improperly or malfunctioning. Did you install the sensor? If so, did it include a new wire harness?
