I have been getting a constant oil warning (beep..beep..beep!) alarm. It will only sound when the engine is running, not with key in on position. The motor gives the normal post of beeps saying everything is normal, then as soon as it starts it gives oil warning beeps while the motor is running. Top oil tank is always completely full.<br /><br />I have:<br />1) tested the float in the top oil tank and it checks out fine. Tried to purge any air from oil system and made sure oil pick up screen is clean in bottom tank.<br />2) measured the voltage from the motion sensor on oil pump and it checks out. (1-5 volt fluctuating on blue white and 12.8 on other wire)<br />3) Cranked the motor with plug wires pulled and oil pump, moved oil (not sure if volume was correct).<br />4) Oil is being used from main (bottom) tank, Gas has green tint going into carbs, and Engine has reassuring white cloud of smoke every time I start the motor.<br />5) I have checked the green and purple wire voltages they appear fine. Moved the green from #4 to # 6 position. (Noticed alarm still sounded with green wire disconnected).<br />6) I removed the tan wire from alarm module and beeping stops. I took temp sensors out of picture and it had no effect. One weird thing that happened was the TACH started working when I removed TAN wire from alarm module.<br /><br />I have learned the above from this group and it seems to plague allot of people. <br /><br />Im ready to break down and spend $189 on a new alarm (MODULE ASY-LOWOILIm currently running the boat with the TAN lead disconnected from the oil alarm module and would like to restore the system to normal but can not locate the source of the problem for sure. ).  Is their any thing else I should try or repeat differently? Any feed back would be much appreciated.<br /><br />MERCURY (2.4L) <br />Serial Number: 0C157092 Model Number: 1200412GD <br /><br /><br />Thanks,
