I have a '99 Mercury 120 HP sportjet engine. It had been running fine until one time I throtled up, and it would only run at 3k rpm. I let it set for about 30 min and it ran fine until be got close to the docks, then it started acting up again. I went home and replaced the fuel filter (doesn't hurt), and readjusted the carbs, and pulled all fuel lines and pressurized to check for leaks (including the on in the fuel tank. Boat ran fine for about 15 min, then it start doing the same thing. So I filled it up with premium gas thinking old gas. She ran fine, unitl last weekend when it started acting up again. This time I notice it was just below 1/2 a tank of gas. So, I top the tank off andshe started to run fine again. I have check the electric fuel pump and it is working great.<br /><br />All thing seem to be pointing to the Mechanical Fuel Pump? I just need a second opinion.<br /><br />Thanks,<br />Lan
