After running for about 45 minutes at both idle and on plane, the high temp alarm (according to visual indicator) sounds intermittently. The temperature gauge indicates 140 degrees, the same as the other engine. If the engine is turned off and the ignition turned back on again (engine not started yet), the alarm sounds consistently at 2 second intervals with alternating high temp and low oil warning lights indicated. If engine is then started, the intermittent high temp alarm situation occurs again. The engine also seems to have only about 60% of it's power when attempting to get on a plane after the engine gets in this mode. After engine is off for an hour, the engine is still in this mode.
