Moody Blue
- May 24, 2004
- 3,136
1993 Mariner 4cyl 40hp only runs at 90-100 degree F after running at 3/4 - full throttle for 30 minutes. Have installed a temp gauge and sending unit to factory port on power head. I checked the gauge accuracy before installing on the motor. The sender is located on the head between no2 and no3 cylinders. The head temperature is mildly warm to the touch and is hotter at the top than at the bottom. The telltale stream is quite hot but I can hold my hand under it without getting burned. Is this temp normal? Can it affect plug fouling, fuel consumption etc? I thought it would have run hotter. Better too cool than too hot I guess. Is there a thermostat or other temp regulating device that I haven't found?<br />Thanks for any feedback.
