quantumman29
- Jul 15, 2004
- 105
its a 1998 mercury 150 efi "nitro series" outboard....<br />when i hook a hose and ear muffs to the lower unit,the water comes out extremely hot,too hot to even touch, i used the boat last week and it idled and ran at low mph just fine, and it pumped water in a nice stream from the tell tale,<br /><br />however,when i tried to get the boat up on plane and the rpms increased,the overheat warning immediately came on and the engine stopped pumping water....<br /><br />i shut the engine down,waited a few minutes,restarted and made it back to the launch very slowly,the engine pumped water all the way back to the dock and it didnt overheat...<br /><br />i had this similar problem last year during a tournament,the boat was fine all day,then the over heat warning came on and i shut the engine down, a few minutes later after i went in reverse then forward to clean the intakes out,the boat ran strong all day......<br /><br />im very concerned about the high temp of the water being pumped thru the engine even with a garden hose and ear muffs attached...<br /><br />1) impeller ?<br />2) water pump?<br />3) head gasket problems?<br />4) thermostat problems?<br />5) clogged intake lines?<br /><br />i bought the boat last april,i never replaced anything on it,i used the boat 7 times, according to the dealership,the boat was supposedly in top mechanical condition when purchased, engine only has maybe 7  hours use since i purchased it...<br /><br />any help or advice would be greatly appreciated,i just ordered a repair manual and im pretty good with tools.....<br /><br />                   thanx,<br />                      mike
