Re: cooling on mark 78
Hard to say, probably depends on the lake temperature, too, if it's warm this time of year the motor will of course run a bit hotter. No 'stats on this one Fer Sur!<br /><br />I'd still go by the old 'feel' method, if the exhaust plate isn't getting real warm you've got more than enough water going thru the motor. The exhaust will heat that plate up astronomically if there's not a lot of water flowing thru it.<br /><br />If you can lay your hand on the motor for a few seconds, and it feels quite hot but not burning your hand off, that's about 140 (which this motor should never see). Comfortable to lay hand on for extended periods, probably 120 or less. Can't even touch for a second, 180 or better and you'll be seeing lots of steam at those temps!<br /><br />Or, go the Scientific route and pick up a cheap infrared thermometer from Rad. Shack to get a precise read on engine temps.<br /><br />On the reverse thing, you've got more backpressure against the exhaust when going in reverse; this would force more exhaust, and with it more water, out the exhaust relief in the center section.<br /><br />One thing you may want to check if you don't have a Warm Fuzzy about how much water circulation you've got, is to remove the cyl block water jacket cover (back of the block, over the spark plug holes). Check for buildup of silt/trash; sometimes it's halfway up the block. You can even cut your own gasket if you can't find one anywhere, just pick up some bulk gasket paper from the auto parts store. If the bolts don't want to cooperate, this may not be a great idea unless you feel there's really a problem. You'd have to pull the powerhead to get any reluctant lower bolts or if one breaks.<br /><br />I've got a decent old MK 78 laying in the garage, waiting for a full restoration when I retire. Years ago I picked up an old 700E Dockbuster for $25. Just had to clean the points and fix a busted pump housing with JB Weld! (things were so much simpler then!!!). I ran like a jewel, and I drilled ventilation holes in the prop so exhaust would spin up the motor better for skiing. It was a real Screamer on a 13-1/2" Sea King runabout and we slalomed all summer with it! Definietly a low-budget operation!!!!!<br /><br />These motors look great on a classic 'glass or wood boat, that's what I figure I'll do with mine after she's restored to her former glory.<br /><br />Good Luck with yours and enjoy........ed
