I am looking at buying a Merc 60 motor (1963-65 not sure on year). I ran it a bit in a barrel and it ran very well. However, the water flow from it is very minimal. I suspected the water pump impeller but the guy that I am buying from says that it was replaced just prior to him purchasing it and he has very little hours on it since. Therefore, I am suspicious of other causes such as blockage in the line. I know I have read about sticking a wire up in the pee hole to try and clean this out. What type of wire and is there any risk of damaging any of the line or anything at the other end?<br /><br />The motor also has a plug located just up from the pee hole that is labeled "Fresh Water Flush". I figure this is for flushing the system after running in mucky or salty water? I took this plug out and discovered that the hole is completely plugged with what appears to be lime or calcium from the water. I can scrape some of this out easily but should I use the wire trick on this as well? And could the blockage that I am noticing be caused by the area rather than the pee hole?<br /><br />Thanks in advance for your replies.<br /><br />Brian
