Re: Forward is Reverse and Reverse is Forward
Yanno... I just looked at the exploded diagrams and I don't see how it could be made to shift fully into both forward an reverse with the shift shaft 180 out of phase. <br /><br />As for the linkage, the cable connects to a long arm that connects to an aluminum arm about 2-3 inches long. That aluminum arm should be on the same side of the motor as the cables. I don't THINK it could work the other way, but if the mech is long enough AND it all clears the carb, having that backwards could reverse the shift.<br /><br />Only problem with this idea (assuming it could even work) is that none of that up there had to come apart to drop the lower unit to fix the seal. Ditto the shift cable.<br /><br />I can see why he's perplexed, I'm getting perplexed just looking at it. Just trust that he means well and will get to the bottom of it.<br /><br />And remember - if your controller is extending the cable for forward and pulling it for reverse. It's your controller - that simple.<br /><br />I'd go look at a real lower, but they are all down in the storage building, Jean is here, and I hate getting soaking wet unless there's aboat and a rope somehow involved.<br /><br />-W<br /><br /><br />-W
