OK, folks, here's the scoop:<br />Engine starts & idles fine; No problem getting RPMs in the 5*** range while in idle/neutral; put the boat in Fwd & can only get 3200RPMs on full throttle; changed fuel filter and added inline, transparent-casing fuel filter to watch for particulates; filter stays clean, same result
; changed spark plugs; same result
; engine is running ~175 degrees when warmed up and does get up to ~190-200 degrees when running @ 3200RPMs; telltale hole emits water in irregular fashion and water is very hot; my brother insists it's the water pump; how would that prevent boat from hitting WOT @5200RPM when in gear
? Any ideas would be appreciated before I start my wild goose chase!
