I was running out on the lake today, nothing unusual.... After about 10 minutes, I glanced down at the pressure guage and noticed that it was running only at 12-13 psi at WOT compared to the normal 22-23. Took a look at the temp. guage and it was reaching up to 220F (head metal temp.). So I immediately throttled down and the pressure jumped around a bit with the poppet closing, and then it settled down to less than 5psi probably around 2500 rpms and the temperature immediatly increased to near 240F... Didn't get the alarm but quickly shut it down, knew I had a problem... <br /><br />Got it going about 20 min later after running the trolling motor towards the marina. At idle or up to 1000 rpms I had a wopping 1 psi of water pressure... The engine was still running good at least at idle/no-wake speeds, but with only a very weak/constant stream of water with the t-stats opened and running at 180F....<br /><br />I Made it home ok
.... Checked compression, all at 115-120 psi.
Whooo!..... Checked poppet, OK
... Pulled lower unit and expected to see a fried impeller assuming that maybe I tilted out too much today and lost water causing it to fail.. After removing the water pump housing I was suprised to find that the impeller was in perfect condition.
.. But after looking closer at the rest of the pump, look what I found...(Gasket Problem)<br /><br />
<br /><br />Just thought I would let everyone know about this... Amazing that a gasket for a pump cover can almost cause an engine to fail... I'm lucky today... I will diffinitely make sure I torque that cover down correctly next time, as that gasket is only a year and a half old...
