floridacamper
- Oct 23, 2004
- 3
Please help. My boat has been in the shop on and off since July and still it is not fixed.<br />This what I have, it is a 1996 40 Mercury outboard and I have it on a pontoon boat. What happens is that it will run about 10 minutes then it want idle and it want take hardly any gas. They the boat mechanic went into the cards redid them gave me a tune up but he says it is sludge in the bottom of my gas tank. Well what happens he says is he cleans out the carbs and then after ten minutes or so of running the carbs get dirty again and it quits running. It should be noted that the carbs start leaking gas when this happens also. When I first took it to him it didnt leak any gas just would die after 10 minutes or so running. What do you think? H did replace the fuel hose and bulb also. I emptied out the gas tank and rinse it out with gas cleaner before refilling it with good gas today and it did the same thing. HELP!
