Here's the problem. 97' Mariner 150 won't tilt, trim, or hold position. When I manually tilt motor full stroke, I can hear fluid squirting or bypassing internallly, though it seems like far too much to simply be a bad o-ring. I have a factory manual. Here's what I've checked. 1. trim motor both relays operate.<br />2. Disassambled port trim cylinder replaced o-rings, inspected check valves in piston for FOD (none)& blew out checks with compressed air. 3. Removed & disassembled pump everything seems pristine inside, no excessive wear. 4. Replaced manual byass valve & o-rings. <br />I have not done anything with the main tilt ram.<br />Questions:<br />1. Can the pump look so good and yet be bad, the check ball seats looked perfect? <br />2. Are there any tricks to getting the system bled of air? Airlocked.<br />3. This is beyond the manual, but what should the side clearances be for the pump gears?<br />I'm a capable DIY'er.<br />4. Short of blindly replacing the pump, what else can I check?<br /><br />rodbolt, outboard Doc, DHPMARINE, or any other knowledgable soul<br />This seems right up your alley please HELP<br /><br />Many thanks in advance<br />Waddell
