Re: '83 merc L/U
As long as the 50 is a 3-cylinder. I've only ever seen one of those. Otherwise you'll see mostly 650 triples and 70 triples. Don't confuse the 650 triples with the 650 4-cylinders or the 50 triples with the 50 4-cylinders. Only the triples will fit other triples. The gear ratios might be slightly different (I doubt it), but that can easily be compensated with a slightly different pitched prop.
